Besides a direct box.....
  • Thread starter Thread starter stinkfish
stinkfish
What are some of your favorate methods of recording the bass?
What kind of mics etc...any thoughts would be appreciated.
I mostly just plug my bass in direct and record it that way. Mess around with the eq a little bit to tune the sound to your taste. I have miced a bass amp before though and i find that using a AKG D112 gets a good sound. just place the mic about 3" or so away from the speaker and set the mic a lil to the left or right side of the center of the speaker.
Scenario 1: DI & Cab
1st ch. Bass --> DI (Countryman/Radial) --> Console/Pre amp
2nd ch. DI --> Amp (Orange) --> Mic --> Console/Pre Amp
So then they are coming down say channel 1 & 2, then i blend the "clean" (di) & "dirty" (amp) to what i feel fits that particular song.
Scenario 2: Cab
1st ch. Bass --> Amp --> Mic (dark mic) --> Compressor --> Console/Pre amp
2nd ch. Bass --> Amp --> Mic (bright mic) --> Compressor --> Console/Pre amp
The idea being that if you balance the low frequencey and high frequeny microphones, you can get a more accurate representation of what the cab sounds like. I have used this technique a couple of times, after i read about it in an interview with Steve Albini.
Some mics i've used on the cab:
AKG D112, ATM 25, EV RE20, Beyer M-88
In addition to this, usually i'll compress at about 3:1/4:1 (3db), soft-knee, unless its slap bass than hard-knee.
Miking Cab Techniques. (Click on "stringed instruments" on the left, than E/gtrs/Bass up top)
Scenario 3: DI
Bass
Direct - OR -
Bass -> Impedance Converter -> EQ -> Compressor -> In
Thanks for the ideas guys! And the link....that looks like a very useful site. I will give these a try tonight! :)
I will use a Beta 52, D112, 421, 4033, sometimes even a 57 if the bass is way too muddy. I always combine it with a direct signal.
