crosstudio
if you really want to know what the sampling rate means for digital music this little page gives a good example:
how sampling rate works
even better explanation
the long and short is this:
the sampling rate has no direct effect on how high a signal you can hear. the sampling rate tells how many times per second a snapshot of the original sound is taken; however, because a higher frequency changes its sound faster, taking more frequent snapshots will help to more accurately portray that upper range...
hence an even greater perceived improvement in clarity in the upper range with a higher sampling rate.
[edited note] a higher sampling rate will in fact enable the recording of higher frequencies, but you can't hear them.
48khz vs. 44.1khz: 3,900 samples per second difference. which makes your recording of the original sound 8.125% more accurate.
96khz vs 48khz: 96khz is twice as accurate at representing the original sound.
16bit = 2**16 = 65,536 variations in sound pressure that can be measured.
24bit = 2**24 = 16,777,216 variations in sound pressure that can be measured.
that means that 24bit recording represents the sensitivity of the sound with 256 times more accuracy.
although we are MOST DEFINITELY comparing X to Y, you could make the argument that an improvement multiple of 256 in the Y is better than a 2x improvement in the X where X is time and Y is sound pressure at some X-time.
think of it this way:
a computer monitor that is .25 dot pitch and uses SVGA is going to be a better looking monitor than one that is .28 dot pitch and is VGA because the former has more pixels per inch and more color variation... digital music is the same as digital video but the "screen" is linear.
ynamic Range, 2: Signal to Noise Ratio
