B
brainofj
Has anyone tried the v-amp pro?? Seems like quite a good buy over here, cheapest ive found it is 99 pounds.
You can. Use a proper coaxial cable and sync the audiophile to the V-amp.brainofj said:Regarding the S/PDIF output on the rear, is it coaxial rca connection ? I have an audiophile 24/96 which has an S/PDIF in and out, (RCA), i was hoping that i can connect the v-amp to this.
That's what I meant. Just don't use RCA audio cables. They can work but the connection can easily be lost (at the worst possible moments).riotshield said:You need one that is 75 ohm (sometimes marked 'RG-59/U' on the cable. Usually RCA video cables are 75 ohm.
