B
BABAYAGA
Hi All.
I have a Behringer mixer which suddenly developed a problem. Power is going to all the components, but when I feed any of the inputs (from a CD player for instance) I can't get any output from the mixer at all.
I've tried each channel in turn, and also the CD/Tape inputs. I've also made sure that the channel output selectors are set correctly when testing. I've taken outputs to my powered monitors from each of the outputs on the rear panel (control room, sub and main). I also plugged in a set of phones directly to the mixer and they were dead as well.
Even with the inputs all up maximum, the led channel lamps don't illuminate, so I'm thinking there is a fault somewhere on the input side of the mixer.
Has anyone had similar problems before? I was wondering if it was something I could look at myself or did I need to put it into a repair shop to be looked at?
Any advice you could give me would be much appreciated!
TIA! Cheers - Graham.
