Behringer ADA8000 - How to get input signal thru to the line outs (w/FS-160)?
  • Thread starter Thread starter cmayo
Or, as I stated above-on the second 8000, you use mic input to the 8000, ADAT out to ADAT in. and analog line out to the line ins, #'s 5-8, on the Digi. The 002, at least, only has preamps on channels 1-4. Channels 5-8 are line-in only. 9-10 by SPD/IF. Channels 11-18 by ADAT. So- what the second 8000 can do is give you preamps with mic ins for channels 5-8.
Yeah, that will work, but I'd shop for an alternative.
Seems a bit much to go a/d-d/a just to get use of half of another ada8000.
I agree. That's why I only use one. Channels 5-10 are serviced by outboard preamps. I use the S/PDIF out on a JoeMeek twinQ for 9-10, and an Avalon and a Pendulum on channels 5-8. But- the OP asked how you would use 2 ADA8000's into a Digi003. I was just pointing out that all of those 1/4" jacks on the back of the ADA8000 aren't inserts. They are balanced 1/4" line outs, and nothing comes out of them without some kind of digital input. No digital in, no analog out. It's not a mixing desk. I got the 8000 just to access a lot of channels for a Sci Fi radio play that calls for a lot of simultaneous open mics. And for what it costs, the 8000 is a very useful box.
Hi all
Thankyou for the suggestions. Would any one know if its possible to get a firewire or usb to adat converter to gain me the extra 8 ins and outs .
Many thanks
Hi all
Many thanks
Unfortunately, that question has already been answered. The Digi003 only supports 18 channels. Anything else would have to be submixed. The simplest solution by far is- get another 003. They should piggyback just fine.
