Johnny Rico
Hi, I'm learning to use FX bus to uses less CPU ressources when I need to get many guitar tracks with the same amp simulator and the same presets.
I used to learn this technique with Overloud TH1 on a project with two guitars , one panned 100% left and the other 100% right, the result is great, only one TH1 instance with the same sound resulting on two different guitar tracks panned in stereo.
Sadly, it appears that every other amp sim I used with this technique don't work in stereo: with the same setup, the two guitars are not panned in stereo, they remain in the center of the panning, like if they were mixed in mono.
The same result is meeted with Revalver, Amplitube, and some other freewares...
I use Reaper 3 as a DAW.
Does this problem is considered as normal, and should I conclude TH1 is a (great) exception ??
Is there any tricks I may get to help me in this way ?
The main objective is naturally to keep CPU ressource, and not to be forced to use an instance of any amp simulator for EVERY guitar tracks...
Thanks !
(hopin this thread will be understood by all, I'm french)
Thanks !
