Battery Latency
  • Thread starter Thread starter probestyle
P
probestyle
I am using cubase sx with a delta 1010 interface. I am new to battery and I am experiencing latency issues when trying to monitor my playing while I record my MIDI drum track.
The latency only occours when I am monitoring and using the sounds in battery. If I record and monitor the sounds from my td-8 I have no prob at all.
Once the MIDI track is there I can then switch my output back to Battery to record the audio tracks and there is no prob with that.
So the question........ Is there a way to monitor the sounds I am triggering through battery while I am recording with no "noitceable" latency? Either through hardware or software settings.
Thank you in advance
Chris
There's actually a latency setting in most sofware packages. Make sure it's set as low as it can go without losing notes. Another factor will be your processor speed and midi drivers.
