scared_of_girls
OK, this scenario/question is quite specific and detailed but hopefuly a few different people can provide little bits of insight and I can build up my understanding.
First up the gear:
Ibanez Ergodyne 5-string with active circuitry
Fender BXR 200 combo
Behringer Eurorack UB2442FX mixer
Maxi Studio ISIS 8in/4out PC interface
Logic Audio Pro ISIS virtual studio
The main issue is getting the bass sound into the mixer, after that I'm fairly right.
The amp has both a 1/4" and XLR Line Out so I would like to use the XLR as I assume (first point of clarification required) it is balanced. This is post chorus and compression.
If this is balanced (and I don't really see the point of XLR if it's not) is this what many articles refer to as a built-in DI? I kept being told that most modern bass amps have a built-in DI but I'm not sure if that's something a little different.
The next question is around the connection with the mixer. Each channel has both Mic (XLR) and Line (1/4") inputs. The Mic input has an invisible pre-amp so I dont think I really want to use that. The Line input says "BAL OR UNBAL". So ... can I get (do I need) a balanced XLR-1/4" cable to make the most of this? Is there such a thing? If so, is the 1/4" a stereo (TRS) plug?
Os should I just buy a little DI and be done with it?
I have tried a standard instrument cable out of the 1/4" and into the 1/4" Line input - it is noisy. I've also tried a combo of close-mic SM57 and medium-mic Samson C01 condensor which is much better but I would like to blend in DI as well (also got a Realistic Pressure Zone Mic for room sound). I want it all!
All comments greatly appreciated.
First up the gear:
