Joel Hamilton said:Multiple compressors help with this a LOT. Better to have a few things, not doing as much individually, than one thing doing a LOT to the bass.
Try not to EQ, just compression and GAIN. Use gain and placement as EQ...
Try high passing... get it to sound like a HUGE bass without eating headroom so much....
Good bass players make bass easier to manage.
7string said:Explain 'placement' please. I use compression and a bit of EQ after the compression but I'm not sure which direction you are coming from on the 'placement.'
Joel Hamilton said:Meaing the amount of gain you use to make the bass feel "forward" or "present" as opposed to "round" or "dark" or "inside" compared to the kick. It is amazing how much you can change the way something sounds in relation to the other sounds you are working with, simply by returning it hotter to the console and attenuating at the fader, rather than returning quieter and gaining up at the fader..
teainthesahara said:Would that be a mixing-in-analog techique, and, if it is, is there anyway to acomplish that with ITB mixing?
chessrock said:I think you guys are way over-analyzing this stuff.
Just get a good bass with semi-new / broken-in strings.
Track, and you're done. Compress the holy hell out of it if you have to.
If it doesn't sound right, then you probably messed up one of those steps. Boo-hoo. Find out which one it was, and correct it. This shit ain't rocket surgery, you numb nuts!
Joel Hamilton said:The concept is more about how to approach a mix, but this is becoming a super duper thread hijack.... If anyone cares, we could start a new thread about gain structure I suppose....
