CoolCat
Just posting a DIY so maybe someone else will stumble across it and save a few bucks on a possible repair.
Bought a nice used solid state bass amp on craigslist lasted a month or so, went through practices and gigs., and then this week, an extreme loud buzz/hum. BUZZ/HUM Sound was very loud nothing plugged in and no volume.
Some articles mentioned swapping ac outlets, ac cords, then tapping on the head (which can be a caveman check for bad solder connections). When I gave the amphead a good punch the Hum disappeared.
Next was removing the amp from the combo/cab. plugging it in and as one poster mentioned, with a wood poker tap around and see if the loose component could be found. Other posters mentioned the Large Filter Caps next to the transformer are known for coming loose/cold solder joint/bad solder joint.
Poking with the wooden poker on the filter cap re-created the HUM/BUZZ.
Next was unplugging, disassembling and touching up the large filter cap solder joints locations. Problem fixed...
Time it took was about 45 minutes to 1hr.
Just thought I'd post to pass along the DIY repair notes for someone else.
Amp= Fender Bassman 400
