C
CelesteMac
I have a basic home recording system, Scarlett 2i4 and Garageband 11. I use it mainly to get better as a singer and occasionally to share songs with friends. Nothing fancy.
Is there a way I can set up two headphone mixes, one for recording, and one for playback, and switch between them easily?
A typical scenario for me is recording my vocals over music that it is already recorded (I play piano or use backing tracks) and/or recording harmonies for lead vocals that I’ve already tracked.
The Scarlett has a pan for monitoring what’s being recorded versus what’s already recorded, and getting that mix right in the headphones with the right overall volume is key in getting good vocal recordings. But then listening to the playback involves changing that mix and changing the volume, listening, then changing it back, between takes. Meanwhile you’re standing at the mic, fiddling with the dials all the time.
Yes, sometimes, I just record several takes straight through but especially at the beginning of a session, I need to take a listen to what I’m getting.
Is this something that I'd need software plug-ins to do?
Thanks!
Thanks!
