Okay so I have a tape deck that has unbalanced (RCA) inputs and outputs. And I have a hand-built mixer from the 70's. The previous owner pulled a lot of chips so only the pres and eqs and the buss outputs are working.
The mixer has all XLR inputs and outputs - 16 mic inputs and 16 line inputs and then 8 output busses plus stereo out (disabled), echo out (disabled) and some monitor outputs (one of them works). The master section (chips missing) is dead.
I'm having problems getting the buss signals to pass though a patchbay to the recorder. If I take the 8 buss outs and send them into another mixer (Mackie 1202) it works fine, but if I try to go through a patchbay to the recorder it doesn't work.
Maybe it's that the buss signals are balanced going into the patch bay, and I'm sending an unbalanced signal out to the deck? I can't get the meters to move on the deck unless the signal's from another source (e.g. drum machine).
For the Line ins I built a snake with RCAs on one end and XLRs on the other. I wired pins 1 & 3 together - I ran the outputs of the deck to the line ins on the mixer - works great.
However, the snake I have for the 8 Buss outs has female XLRs on one end and stereo-type 1/4" jacks on the other end (I didn't realize they weren't mono jacks when I bought the snake).
Should I build a new snake or modify the one I have? If so how do I wire it? Or is it something else entirely?
