Massive- to answer your question: The aural exciter is "primarily designed as an in-line device".Though it can be used in an effects loop, "the signal being received back into the console is not pure effects". I have a few songs which, though performed excellently and recorded on high-quality mikes, have instruments which lack a large amount of high-frequency content. After trying eq, I found that this box did the trick just perfectly (if used correctly). Since I don't want to pass these digital tracks (on my Roland 16-track) through another DA-AD conversion, it would be good to have only the effect sent back in to mix with the original signal. Since the Aphex 204 is two channels and I only ever need one at a time, I can afford to alter one channel to use in an effects loop situation.
lumbago- I have found a "simplified block diagram" in the manual since I posted this, and it seems that Massive is right. It shows the original signal being summed with the Aural exciter sidechain right before the output. So I think it should be possible to simply interrupt the signal path of the direct signal right before the sum.
I just need to figure out where that occurs.
Does anyone else know which component I would need to remove, and whether doing that would cause the other circuitry to fail?
