Audiophile 2496, Sonar 2.0, and MIDI
  • Thread starter Thread starter VertuGoGo
V
VertuGoGo
hi all, my name is Gene and i've been posting on the cakewalk forum but i'm new to this one.
we are recording drum tracks tomorrow using a roland electronic kit, and i have some concerns.
first, i can't hear MIDI with sonar. i used to be able to when i had my soundblaster 5.1 installed, but since replacing it with the audiophile i can't hear the midi tracks from one of the tutorials anymore. i tried cycling through the different outputs and still nothing. i made sure that my sound card, among others, is highlighted in the MIDI devices menu, and still nothing. BUT, last night while fiddling around, i got to hear the virtual keyboard from another program (Unity DS-1). so it seems that i CAN hear MIDI, but not in Sonar. however tonight the keyboard sounded crappy (delayed, chirpy sound).
i know we can record the drum tracks as audio, but i'd rather do it through MIDI so we can split the tracks and edit each drum and cymbal like you would if you were to mic a real drum kit.
i have a plan that i hope works in case we can't hear any MIDI tomorrow: we'll record anyway through MIDI, split the tracks, then play back each track while simultaneously recording it into an audio track. i'm hoping that even though we may not be able to hear the midi track playing back that it will still record into an audio track.
any insight as to what is going on inside my computer?
UPDATE:
ok, after reading through various help topics in sonar, i decided to check again my volume settings (i have XP btw). i went to control panel, sounds and audio devices properties, and on the audio tab decided to make "Microsoft GS Wavetable SW Synth" as my default midi music playback device. i already had tutorial 4 open (it has MIDI tracks). lo and behold the damn thing plays! i can hear all 3 midi tracks loud and clear. i decided to open another tutorial (#8) but when i did i heard nothing again. i made sure the new settings i did are still there and they were. what IS going on inside my computer?
The main issue is that you need midi playback devices. When you record the midi of the electronic drums you will still need to have the drum 'brain' attached to play back the sounds. At some point you will need to record the audio tracks also.
Your soundblaster had a built in midi synth but the Audiophile does not. You can use Softsynths but they can have latency and quality issues (as you are discovering) depending on your system performance.
If you want to use midi and need a built in midi synth than you might want to reinstall the SB. It should be able to function along side your Audiophile as a midi playback device.
yeah you guys are right. last night we recorded the drums. i forgot i had the midi metronome enabled, cos when clicked on the record button, there went that hi-hat counter hehe. we were connected to TD-10 brain so the program was using it as a midi device.
about installing the SB just for the purpose of midi playback, i was told that having two soundcards installed will "confuse" the computer and just cause problems. anybody have two sound cards installed for the same purpose with no problems?
my friend suggested to go to ebay and bid on an inexpensive midi module. anybody have any recommendations or brands, types, where to get one, etc...?
thanks again for all the replies. you guys saved me hours of headaches.
I have used 2 cards in the past, but looking into a external midi device would be a better option. Find yourself a modest keyboard to get the most sounds out of the situation. A midi keyboard will be basically the same as your SB with 127 sounds to choose from. I would check ebay for a Yamaha PSR model. You can probably get one for less than 100 bucks.
