R
rathpy
[Moved this thread from newbies]
Please answer some dumb questions and help me make a more informed choice for the M-Audio cards…
Q1.
If I want to connect 3 MIDI devices (say a Pod, a keyboard, and a drum trigger-to-midi device), I only need one MIDI output and input from my PC, so long as I can chain the devices via MIDI through ports on the devices, right??? (I know the POD doesn’t have a through port).
Q2.
Can I get an Audiophile now and add a Delta 44 to it later? How seamlessly would this work? Would latency be increased?
Q3.
To process a pre-tracked DI’d guitar through my Line6 Pod and be able to listen to the effected mix I’d need 3 outputs: 1 for the guitar part + 2 for monitors, right? (Sorry, may seem obvious, but I haven’t played with this stuff before).
Q4.
If the above scenario means that the Audiophile by itself is insufficient (because it has only 2 outs), could I use combination of an Audigy (OEM card only) with either a Delta/Audiophile. This would give me all the connection numbers/types I need, provide soundfont hardware sampling, and be cheap. But what are the downsides???
Q5.
The M-Audio cards by themselves don’t have a headphone output, so what’s a good way for switching to headphones for tracking? (If the Audigy could be used with the M-Audio cards, I could use its headphone outputs, couldn’t I?) Please note I already have an Audio Buddy on order and I only need 2 mic pres, so I really don’t want to spring for an Omni I/O. My guess is that I either require 2 dedicated outs for a set of cans, or be able to switch in outboard between monitors and cans. Do I need a headphone amplifier to drive a set of Sony MDR-7506’s? A cheap Behringer MX602A mixer? (but then I’d loose any benefits of card balanced outs, and extra mixer noise would be added to the monitor signal?). Hmm, I ‘d don’t have a clue here.
Regards,
rathpy
Q1.
Q2.
Q3.
Q4.
Q5.
Regards,
rathpy
