Audio Dropouts Hell :(
  • Thread starter Thread starter rockem
R
rockem
Hello all,
I'm having audio dropouts with my new computer for the last two months and can't figure out why
here is my computer
Case - Antec Sonata Black Piano
MB: GigaByte 8IPE1000 Pro (replaced from Asus P4P800)
CPU: P4 2.4
VGA: Matrox G550 (replaced from Asus 8197)
MEM: 2x256 Kingston memory (works in dual ddr)
HD: Maxtor HD 7200 40Gb
SC: Echo MiaMidi
WinXP Home. Cubase SX, Halion (all legit)
well, as you can see I already tried to replace MB, VGA and also
all the cable inside the computer
I ran Memtest, was fine
the problem accured randomally I see audio dropouts
and also when I minimize cubase I get a dropout
if I ran with a regular sound card (like the on-board one)
I get no dropouts, but its on 46ms latency
the test project is 3 audio, 2 midi, no effects
please,
any advices will be welcome
thanx
maybe the latency you are running on your Echo card is too low? Have you tried adjusting the buffer sizes etc. with that - are you using ASIO?
Maybe try finding a better medium with the latency...what is the card supposed to be capable of?
Teh drop out from minimizing the audio app sounds like it's related to the buffer in the application itself, not the cards IO buffer. I don't know cubase, but this should be configurable somewhere. If you set this real low by mistake thinking it was the hardware buffer it would explain your problem.
It happence also with a 7ms latency which should be ok
for a computer like that
running only 3 audio tracks no effects
don't know
Just for everyone to know how I solved it
first I installed the microsoft drivers for the matrox g550
which works way better with audio
second, it appears that I had issues with the mia card's driver
and my system, so I replaced it with the audiophile card and
everything seems to fine for now
well.. fellow echo user here..
sounds like it might be a clock problem. Might try setting your card clock to internal (in the echo console) and seting your software to channel 1/2 out....
I had a similar problem once and that cured it for me.
Good luck:)
F.S.
It was on internal as you said it
it wasn't it,
it was a two month problem
