nate_dennis
I'm playing a show next week and want to do a cool little video of the event. I'm going to record the audio seperately. Because of the limited routing of the in house system I will use the tape out from their mixer into a small mixer (probably a eurorack . . .but no behri bashing please, I know they aren't great.) Then I'll use the mic pres in the eurorack to capture room sounds with two SDCs. I'll mix those two sources (the ambient mics and the line outs from the house) into my two channel USB interface. Complicated? Maybe a bit, but it's the best I can do.
I want to use two digital video cameras to caputure different angles of the show. Here is where my main question comes in . . . .
How would you go about syncing the audio to the video? I do have a SMPTE synchronizer (JL Cooper PPS100.) I intend to sync the audio to both videos so that they could stand on their own, then using editing software, cut them and fade them together to make a more polished vid.
I know it's possible to visually sync them, but that's tedious and unreliable. I'll do it if its the best option. But is there a better way? Would my JL Cooper be of use?
Thanks guys!!!!!
-Nate
Thanks guys!!!!!
-Nate
...but it's that much more accurate if you use the same sample rate for everything, even the DAW audio.
