R
RWhite
I just wanted to let everyone here know about a compatibility problem between SONAR / Cakewalk and certain ATI video cards. A thread explaining it all and with links to a work around is over at Cakewalk's SONAR forum:
http://www.cakewalk.com/forum/tm.asp?m=73110
In short, some ATI cards - including the All-In-Wonder - use a WDM audio driver which if enabled prevents the SONAR program from running.
The work around (which I have yet to test) is to disable the driver whenever you are going to run SONAR, and then re-enable it afterward (if you wish to use your ATI cards full capabilities).
I had formerly a similar problem with an ATI audio driver conflicting with my Audiophile 2496 card, but when I upgraded from an All-In-Wonder 7500 to a 9000 model (and downloaded new drivers) that particular problem went away.
And while I'm pissed at ATI, I should say that right now SONAR seems to be the only program having a problem - all my other audio programs are working fine.
