BentRabbit
Rokket said:Mine was at 80 bpm, good job!![]()
The idea was suggested that we do the vocal sections in 4/4 and then jump to instrumentals in 7/8...
Whaddaya think o' that?
It might work....
Actually, I was able to give yours another listen in the studio before I headed out the door (odd how different it sounds when you're NOT listening on the PC speaker at work)
and I can hear where Tenkas was going with the modifiactions to your initial groove... I started recording a pretty basic 7/8 scratch track, based on the canned drum line you supplied (simple modification) and will map it out with your supplied lyrical arrangement... I can give you a few samples to work with:
> Entire arrangement in 7/8
> Vox in 4/4 - Instr. in 7/8 (which, if we're running the vox at 4/4, then theoretically we should keep the TS to 7/4.. but that's just trivial semantics depending on who's playing the chops... It'll end up fitting...)
> Entire arrangement in 7 except for a perceived 'chorus' (gotta keep the lemmings interested sometimes...)
Then, once we get the collab rolling, all parts can be adjusted as seen fit...
I'm going to take off from work early today *cough cough, snicker* and will try and finish up recording these and get them posted...
Or... would you prefer me to send you the drum track(s) and you can lay down the bass line(s) and then post them as a solid rhythm track?
to 4/4 for all verses and chorus
