Armistice
Son of Yoda
Howdy.
I seem only to be able to get a "decent" sound out with this set up by doing some major EQ cutting post recording the track. That's not necessarily the mic's fault, mind you.
Just wondering if anyone has any actual experience doing this with these mics? I've read reviews that say I should be getting a reasonable sound, but just can't crack it.
Currently I'm trying using only 1 of the pair about 25cm (10 in) from the join between neck and body going into a MindPrint Envoice into AW4416. The tone I'm getting sounds severely metallic / middly. The guitar I'm using is an up end Maton, and a quality axe, so that's not the problem. I'm recording in my lounge room with plasterboard walls and carpet, but I've constructed a wooden frame which I drape with blankets etc as a way of damping reflections.
More/different gear is not an option for me at the moment, I really need to work with what I've got - I suspect that I'm the problem, not the gear - open to any/all suggestions as to how to I can improve here. This really is a dud, harsh sound I'm getting.
Type of music varies from fingerstyle to rhythmic strumming.
Cheers
David
Cheers
David
