anyone know any good sites that help with diy amp troubleshooting?
  • Thread starter Thread starter capnkid
capnkid
capnkid
Optimus Prime
The tube amp was making popping sounds and whizzing (up and down oscillating) sounds. I put new tubes in and it seems to have cured the popping, but the whizzing is still there.
what kind of amp is it?
one of the things i never understood about peavey's is that they run multiple ground planes.... ie: if you pull the board up and look at it you'll notice that the grounds on the board aren't neccessarily run together.. they only tie together when mounted in the chasis through the stand-offs they're mounted on... make sense???? so if your working on one and you pull the board up you have to use alligatorclip jumpers to tie them together... well what that means for you is that sometimes grounding and interference issuses can be as simple as tightening the board down... at least that's where i would start... good luck...
