anyone ever get kt drum trigger to work?
Nathan1984
I just discovered kt drum trigger, but I haven't been able to use it. My problem is that I can't get it to enable midi output. I am wanting to use it to trigger ez drummer. Here is what I am doing. I plug in the kt drum trigger soft synth into my kick drum track. I open it up, set it correctly. I then load ezdrummer, and try to select an output, but kt drum trigger isn't one listed. I have tried to right click on kt drum trigger in the synth rack, to enable midi output, but it is grayed out. Does anyone know how to set this up to work with Sonar 8 PE.
never mind guys, I figured it out. So if you guys ever wanna use KT Drum Trigger, and can't figure it out, send me a message and I will point you in the right direction.
It wasn't easy for sure, you have to do all kinds of stuff to get it to work. Real pain, but very useful program if you are doing drum recordings, in lets just say not such a good recording enviroment, like I was.
