A
atomictoyz
Greetings MD8 hacks and users,
On Friday night, I recorded some things on the md8 using the mic/line input on channel 2. Everything worked as it should and I shut everything down as usual, same as the last couple of years. On Saturday morning, I played back what I did the night before and I thought I could do better. I flipped the PB switch and reset the preamp gain to its previous setting, I started to rehearse/warm up and there was no sound, at least other than some unusual noise not found on all the other inputs. I tested the cables and all the inputs, played with the switches and there is definitely a problem with channels 2 mic/line input. Turning the gain up and down makes no difference on the level of noise and that channel still plays back just fine. I copied a track to the 2nd channel and playback worked, but I cannot record direct to that channel. Any ideas? Im throwing around the idea of taking it in to a Yamaha tech, but Im not sure how much or how long I will be without a recorder. Should I get it repaired or just work around not having that mic/line input available?
Peace,
Dennis
Peace,
Dennis
My B-day is closer tho...
