64Firebird
I think I may give it a try. I've been looking around at Schematics on the web for a lot of the classic effect boxes. Looks like it might be fun to try and make a few. Or, I might pull out all my hair.
Toki987 said:I built a leslie for bass once with a fender 12" in it. I used an old sweing machine motor and the pulleys and belt to drive it. I could only use it once for a about 15 seconds in one song cause I couldnt figure out how to recreate the signal connection for the speaker. I hadn`t seen the inside of a Leslie yet except looking at how the drum was built from the outside. So I just had about 10 ft of wire in it that it would twist and wrap around inside that cab. Id spin it back the other way on the break. Then they came out with a flanger pedal.![]()
we had 4 4ft black lights laying on the floor in front of us and everybody wore white suits, it looked like amt7565 said:If you don't have much experience in electronics, you have to start small. It does not matter if you use fuzz boxes or not, that's the only way you can learn.
Start with fuzz boxes and tone controls...then move on to higher level projects.
