Jeff_D
I've been half-heatedly shopping for a new interface for a while now. I currently use two MAudio Delta 1010lt cards in a pc w/ 64bit Win7. While I know there are higher quality interfaces on the market, for the price these have been really good for the past 8 or 9 years now. However, when I upgraded to Windows 7, I started to have issues with them syncing together- issues I never had the entire time I used them in XP. I had to get a cable to link the two together, which I never needed before. And still now, I'll have an occasional issue where one card (the "slave") will start to distort and crackle and the only solution I've found is to restart the PC... at best, thats a hassle... at worst, its a real buzzkill especially if I'm recording someone else's band and I have to tell them that the excellent take they just did would have to be redone while my PC restarts... especially when one of the guys in that band is a Mac guy.
Anyway, I haven't spent a lot of time trying to solve that because a) I don't use my studio *that* often* b) it doesn't screw up that often- maybe once in a day-long session and c) I knew I'd be shopping for an upgrade at some point anyway.
SO. For the past couple years, I've been daydreaming about a MOTU 24io. I already have 16 channels worth of worthy micpres- 8 channels in a Presonus D8 and 8 channels in a Soundcraft M8 board. At $1400+ its a bit of a stretch for me, considering I make very little $ from my studio and considering that's a $1000 upgrade from the $400 worth of soundcard I have now.
I was cruising ebay last night and came across something I didn't even know existed- the 24i. It has 24 inputs and only 2 outputs, which would be totally fine since I mix everything in the box. And at $200 to $400 for one, it seems very affordable. Of course, I understand that I'd need the host card to plug it into and that's where things seem to get hairy. From what I can tell, the pci324s only work in older 32 bit computers and there's something about the PCI bus voltage that I didn't understand. So, then there looks to be 2 or 3 different versions of the PCI424 host card with varying compatibility issues. But, the wierd thing to me is, that it doesn't seem like you can buy just the host card from like musiciansfriend or sweetwater. Then, the other question is, will all of the different rack units work with all the different host cards?
Anyway, if that doesn't pan out, I'll probably look into the MOTU 828mk3 hybrid. MOTU 828mk3 Hybrid | Sweetwater.com I can put the 8 1/4" outs from my m8 mixer into the 1/4" inputs and run the D8 in through the adat input.
Any thoughts? I'm open to other brands. BUT, I really want to keep using my Soundcarft M8 because aside from having nice pre's it also doubles as the mixer for the pa (my studio is also my band practice space). So, I really don't need an interface that has a bunch of preamps built in.
Merry Christmas.
Merry Christmas.
