There are actually a few "rolls" in the song, but I downplayed them because of "performance issues".....
The end roll turned out okay though, so I turned them up a bit.
A pair of AT 4033's to a Focusrite Red preamp to a Behringer Composer (for the Peak Limiting...about 3dB of limiting at most) and all Monster Studio Pro and Studio Link cable to ADAT XT 20's for overheads.
AKG 414 to Oram MWS with a low cut filter set to around 80Hz and a little boost at 8KHz (maybe 2dB) to
a Drawmer MX 30 (Peak Limiter, again no more than 2 or 3dB of limiting) with all Monster cable for the snare.
EV
RE27 n/d to Oram MWS with a tad of 200Hz cut, and 80Hz boosted, and 4KHz boosted (about 2dB of cut on 200, and about 1dB of boost on 80Hz and 4KHz) with all Monster cable for the kick.
A tad of low end roll off at 80Hz on the overheads and a 2dB boost of 12KHz on the snare was the only eq used at mix.
Lexicon LXP 15 on a small room setting with 32meter room, 800ms decay, 30ms pre-delay, 5KHz high cut was used over the snare and just a hair on the kick.
The vocals are a ADK TC 51 tube mic to an Oram MWS with a low cut filter set at 80Hz, and a 2dB cut at 700Hz to
a Drawmer 1960 tube compressor and all Monster cable again. At mix, a tad of a cut at 7KHz, maybe 1dB. Same reverb as the drums. The singer didn't wanted a heavily effected sound for this one. Oh, I also used about 2 or 3dB of compression at mix via a Behringer Composer. I think the sound is "reasonable" but not very exciting.
I don't think the vocal performance was all that hot. Not that he had a hot band playing behind him or anything.....
I almost lost my job over this band. Billed 115 hours, but actually probably worked about 140 hours over 4 weeks on this crap. Even an immortal like me has his limits!!!
These guys are gonna "get signed" and "tour" after they get "radio play" with this release. Remember, this is probably the best performance overall.....
Ed
