jpmorris
Tape Wolf
Depends entirely on the VCR.How do I set recording level to a VCR??
If it's a professional Betacam machine you might not be able to at all, aside from any calibration trimmers on the back etc.
Lance, Mate
I am currently recording a classical pianist at one of Australia's biggest Universities (Monash) using valve mics and valve preamps to 24Bit 96Kbps digital. From this I am cutting DVD-A disc using discwelder. All good.
I also run a second recording which uses a Sony stereo mic, an Elliot low noise two transistor preamp and a Cowon iAudio6 mp3 player line-in @ 128kbps A2D.
My DVD-A's are excellent and very happy. But I could run the Sony and low level noise preamp into a VCR.
I may give it a go.
VHS HiFi was a million miles from a true analog tape recording. It didnt add analog tape compression or tape harmonics. It was so inherently noisy that sophisticated compander noise reduction was mandatory.
Sure, people used it back in the 80's and 90's but they were also using ADAT digital tape based machines mainly because tape was still a more mature carrier than hard disk drives at that time. Read what Dr Ray Dolby said about how the advances in hard drives caught even his analog recording based company by surprise.
If you want analog tape distortion you need more than just a "non digital" machine that uses "tape". VHS HiFi isnt either true digital accuracy or true analog tape warmth.
Compared to what you have, why track to VHS HiFi? What are you trying to achieve?
Cheers Tim
This is a paid job for this guy.
If it was you in that position, would you go out there today and record such a live classical recital onto a VHS HiFi machine?
I have a hunch you would stick with what you have been using solely for the past 10 years and I wouldnt blame you.
Cheers Tim
Though both digital I'm doing two recordings at once. One with the Behringer T-47s, MIC100 valve reamps, and 202 24bit A2D ro laptop using Gold Wave etc,. the other with a Sony Stereo mic (batteries) "sitting" on the piano facing into the noisy beast. There is then a Elliot low noise two transistor preamp (batteries) and my Cowon IAudio6. The Cowon has a line in at 128kbps. A lot of dynamics.
So one recording from two meters back and one right on the piano.
Cheers Tim
If I was committed to getting an analog recording I would haul out my reel to reel machine before I used a hifi VHS. However I believe there is a digital recording already committed so anything analog is IMO more of an exercise to test the concept of making serious analog recordings. In all honesty I wouldn't record with what I've been using for the past 10 years since it represents the industry standard and at this point in time I'm not enamored with the industry standard.
Now I could use my MR8 to record the live classical concert and it would deliver a very nice CD quality rendition of the concert which would be on par with a thousand other CD quality recording devices. No better no worse. If the final for distrbuition version is going to be on CD then 90% of the audio pampering in terms of high sample rates and analog augmentation is going to fly out the window and essentially what will end up on CD 44/16 is going to be what would have been there if the concert was soley recorded on 44/16.
However the idea of making a dual recording digital and analog has merit. But the fullest potential of that merit is to create a digital recording and keeping it fully in the digital domain while taking the analog reocrding and keep it fully in the analog domain. Analog recordings only make sense if they're kept analog. Its curious that you can take a digital recording and record it analog and you have a somewhat genuine analog recording, a kind of not too distant cousin to full analog. But once you make a digital recording of an analog recording it becomes 100% digital and as often as not is the worse for it too.
