elenore19
Slowing becoming un-noob.
So I was crankin' my SCXD because I finally had the opportunity. Yesterday I played a good 20 minutes with the volume close to full on channel 1. (man, that breakup was amazing)
So I went out there again today, hooked it up, played for about 3/4 minutes and all of the sudden the volume went way down. As if I had it at just below 2 volume. Not loud. But I had the volume at 9/10. Then after playing for a couple more minutes, hoping it would fix itself, it got loud again, only to go back to soft after like 10 seconds.
Any ideas?
I'm hoping burnt out tubes (this is my first "tube" amp and I have no idea what symptoms of blown tubes are)
I checked the fuse. It seemed fine. I checked the two 6v6's and they both seemed the same. I have no idea what to look for. I checked the 12AX7, looked brand new.
Is it maybe the new speaker? I put a Rajin' Cajun in there about 2 weeks ago or so.
Any suggestions?
And if you're wondering due to my other thread... No, I have not tried the organ tubes in the amp yet, this problem happened before that.
Elliot
EDIT:Looking at the two 6v6's there are two "lights" in each one, and in one of them you can barely see one of the lights. It's there, but you have to look closely. Maybe that implies tube breakage?
Any ideas?
Any suggestions?
Elliot
