J
James HE
a spoonfull weighs a ton
Im in a trio, drums, bass, guitar, and want to record some demos. I've had my tascam 424 for five years and i'm familair with it but i think I may try a few things i havent before. The problem is getting a good drum sound. The drummers kit is HUGE! like Niel Pert size plus! the only way i can even appoach it is with two overheads and kick and snare mics. simple enough, but i insist on recording live, and without another mixing board... what can you do. I actually bought a cheapo radio shack mixer some time back. I'd like to not use it again if i can. I do have a Crate acoustic guitar pre amp with two channels, so i'm thinking I'll route the two over heads through the pre-amp to get some EQ on them and feed them into the line 5/6 and 7/8 channels into stereo. and use two of the mic/ line channels for the kick and snare mic. leaving the other two mic/ line for bass and guitar, and recording onto two stereo tracks. The four mics that i have to mic the kit are an Audio Technica neodimium type vocal mic (I forget exactly) a SM-57 and two CAD 22. (meager pickings) Which should i use for what? I was thinking the CAD 22's for the overheads, the SM-57 for the snare, and the Audio technica (which has the bass boost that the SM-57 dosent) for the Kick. Or should i use my "better" mics for the over heads. Also should I even try the acoustic pre, would i be better off using the two channels of my BBE (I like to use one to record the Bass guitar direct) Will the tracks that i record going through the line inputs be hard left and right or can I somehow get like a 3 o'clock 8 o'clock type stereo image from those inputs?
