sausy1981
Hi guys I was just wondering if this procedure I use when I start a mix is correct, I'm using a br800 as an interface into sonar producer x1,
1. I put all my faders to zero and adjust the gain on each channel(using the input trim knob on the daw mixer) so that the peaks hit -6db, I generally dont have to adjust much as I pay careful attention to my signal when recording.
2. Then using the pro channel strip on the sonar x1 mixer I put in my high pass filters on instruments that dont need any low end, i.e. acoustic guitar @ 80hz, or bass guitar @ 30hz etc etc
3. After this I go through each track using REQ from waves to further work on the frequencies that need working on, except for the drum tracks, I use the sonar x1 percussion strip to process them.
4. After this I then do a quick level and pan mix, and listen to were I need some compression, which I'll do with RCOMP on whatever trcks need it, mainly vocals and bass guitar but sometimes others, I also do parallel compression on my drums.
5. I then start adding effects such as reverb and delay and tweak where I need to, the problem I have most with effects is with vocals, I use delay with vocals using a very short delay with little or no feedback, I was wondering if I should add a little reverb aswell.
At the moment I wanna be certain I'm doing things right as this is how I've done things for a long time now, but over the last year I've tried to gain more knowledge from the net and reading books and the more I seem to learn the more I seem to doubt how I'm doing things.
Thanks for your help guys, much appreciated.
