stuffdogginc
My soundcard, Soundblaster AWE 64 gold, has a dumb midi in/out joystick port. I have this connected to the midi out/thru of the SR16. I have the midi in of the SR16 connected to a midi controller (evolution mk-125) which only has a midi out. The Cakewalk settings are
send midi start/continue/stop/clock
use start, never continue
use midi start position pointer
The clock is also set to midi sync.
My Alesis settings are midi channel????(I was using midi omni in order to use the evolution midi controller but the midi thru doesnt respond when I do this)
Drum in on V1 (velocity sensitive)
Drum out Off (hmmm...)
Clock in is on
Clock out is off
midi thru in on
prg chng is on
note map is on normal
The end result is, I want cakewalk to be the master, cotrolling the SR16, and still be able to have other thacks on the cake play midi specific to a channel other than 10 which will contain soundfonts. Also there are audio tracks in the mix too. I wast to have the midi data, as well as the audio recording, visible on the cake so I can manipulate ta data using cake's functionality, etc. and record the respective audio to a cakewalk track. Am I too idealistc? I know I'n too confused. Please help.
Clock in is on
Clock out is off
midi thru in on
prg chng is on
