J
jokerone
Guest
PROBLEM:
Alesis Multimix has a hum or buzz coming from one of the MIC channels or the Main Mix.
This was the case with my Alesis MultiMix 16 USB 2.0, but it seems to plague all of the new MultiMix mixers that use the same
Power circuit board with capacitors 2200uf 35v and 1000uf 35v.
After doing a bunch of research multiple people were claiming replacing these two capacitors would fix the problem. They were right.
When I inspected the power board the 2200uf capacitor was budging at the top just like everybody else who has reported this problem.
The biggest 3 capacitors on the board were also glued down with a really tough rubber cement of some sort. I was worried I would break the board prying them off, but I finally got them off. Your board may or may not have the glue on them. It seems Alesis really didn’t want those capacitors to go anywhere.
I copied down a list of all the capacitors on my board (9-40-388), which seems identical to the 9-79-388 because it seems to fit all the newer (dark case) Alesis multimix mixers. Board ID : alesis xf1/6/7 power pcb
Capacitor List:
Capacitor Voltage Quantity
47uf 50v 2
100uf 100v 1
47uf 100v 2
47uf 25v 2
2200uf 35v 1
1000uf 35v 1
100uf 35v 2
330uf 25v 2
If this happens again, I’m going to replace all of the capacitors, but the only ones you probably need to replace are the 2200uf 35v and 1000uf 35v,
which is what I did with total success!
I replaced both of them with Panasonic FC series which are highend audio grade, and only cost about $1 each.
Total cost with shipping was less than $8.
I looked up the board and found this. They want $110 for it.
PCB, POWER ASSY - MM SERIES
I ordered the Panasonic FC series capacitors from Digikey.
DigiKey Electronics - Electronic Components Distributor
After I ordered the Panasonics, I found ones that are probably better for high end audio applications and about the same price.
Nichicon Muse (Premium)
Mouser Electronics - Distributore Componenti Elettronici
Mouser #: 647-UFW1V222MHD
Mfr. #: UFW1V222MHD
Desc.: Aluminum Electrolytic Capacitors - Leaded 35volts 2200uF 20%
Mouser #: 647-UFG1V102MHM
Mfr. #: UFG1V102MHM
Desc.: Aluminum Electrolytic Capacitors - Leaded 35volts 1000uF 85c 16x25 7.5LS
Another source is Parts ConneXion - The authority on hi-fi DIY parts and components
They stock the ELNA Silmic II Series capacitors, but I not the 2200uf 35v I needed.
VIDEO SUPPORT (HOW TO):
This video was a great help in putting things back together. Which I always seem to have a problem with.
Fixing hum in Alesis MultiMix - YouTube
I hope all of this helps.
thanks.
Capacitor List:
47uf 50v 2
100uf 100v 1
47uf 100v 2
47uf 25v 2
2200uf 35v 1
1000uf 35v 1
100uf 35v 2
330uf 25v 2
Mfr. #: UFW1V222MHD
Mfr. #: UFG1V102MHM
thanks.
