Alesis Multimix 16 USB 2.0
  • Thread starter Thread starter ThatsNotMe
T
ThatsNotMe
Hi everyone, new poster here. I bought an Alesis Multimix 16 USB 2.0 this week and while
I am enjoying setting it up, it's frustrating at the same time. I have a Dell Inspiron Laptop w/XP and Cubase LE4 that came with the mixer (I have Pro Tools LE 8 on my mac but first time with Cubase). I am having trouble getting all 16 channels to cooperate simultaneously with Cubase. The software recognizes the board and I am able to record from channel 1 to Cubase but that's it. I was wondering how do you get Cubase LE4 to recognize all 16 channels? (18 w/Main Mix & Alt 3/4)
Thanks in advance! Sorry if I didn't make any sense at all with this.
Did you assign the inputs under VST connections?
and choose the Alesis driver under Device Setup?
I did. Right now I have it set up as 8 Mono Inputs and 8 Mono outputs.
It says "Mic_Line_In_3" "Mic_Line_In_4", etc. - is that what it should be?
And I do have the Alesis USB Audio Device Driver under Device Setup. Under the
"Alesis USB Audio Device" in Device Setup it shows that "MIC_LINE_IN_1" (through 8) are "ACTIVE" (For "LINE_IN_11" through 16 it shows as "Inactive".
and only LINE_IN_9 and LINE _IN_10 are "ACTIVE". For "MAIN_MIX_IN_LEFT" it shows "Active" but "MAIN_MIX_IN_RIGHT" it shows "Inactive"
And your only getting input through channel one? Make sure you have the latest driver first and make sure your USB port is 2.0 not 1.0
I am pretty sure the inactive state changes when you assign the input to a bus under VST connections
- click add bus, select an inactive port
once you assign them all you will need to save it as a template or you have to do it for every project
I run stereo out
You need to also select the input buss for EACH channel you create in the inspector window in Cubase. Input buss for a newly created channel is always Mono1 by default. There is a shortcut to automatically select them in chronological order but I cant remember it.
Jimmy
