J
jeroen_den_haan
Hi there,
I already read lots of stuff here on the alesis multimix and its troubles with the firewire connection. I got one last week, and have not been able to get it fired up so far.
I downloaded and installed the latest drivers from alesis website, no problem. You get the message: "connect your multimix firewire cable any time now". I did, nothing happend. I manually started the add new hardware wizard as descirbed in the firewire FAQ, but hte multimix is not seen by my PC.
Hence tried the firewire card they recommended (belkin F5...), no progress either?!
Tried my videocamera with the same firewire card, no problem, showed up and worked flawlessly.
Any suggestions?
Also tried all possible start up routines. first pc then MM and vice versa etc.
Any suggestions?
