Alesis 3630.
Guys I just thought I would kinda lend my two cents on the 3630. I bought mine new and am happy with it for the price that I payed for it. I have much bigger plans for a compressor in the future but this will hold me off for now.
The sound of the unit (at least my unit) is fine with not click pops or other artifacts when used with light to medium compression. On the gate side of things the unit also works well and when used correctly produce good results.
Now on the bad side of things? This compressor works well but the problem lies in the output gain. When you compress a signal this unit does it's job but when you need to raise the output gain to compensate, your signal gets killed when used with deep or high ratio compression. When used with light or medium compression and keeping you output gain to a minimum you can achieve your goals in most cases.
I think this compressor when used in live performances would do the job nicely. The reason it would is simply because the noise level of the output gain can't be heard or isn't as noticeable in a live situation due to other electronic noise from guitars, amps, mics and the the talking of the people in the venue. In a recording it's the total opposite. The noise from the 3630 can be heard and gets printed while tracking, leaving most people who own this compressor unhappy thinking this unit would translate in a recoding.
If I new what I know know about this compressor I would have to say, though this compressor can be used with careful settings I wouldn't buy it. I would save my money and get something that could do the job in any place that I need it to. So if who ever started this thread and asked if he should get the Alesis or the Behringer I would have to say neither. Save your money and get some thing that is going to give you many years of satisfaction instead of disappointment every time you would like it to do something it just can't.
While where on the subject of compressors what does everyone think of the Focusrite P6 TrakMaster unit?
Later
sonicpaint
