I'm hella confused on the A/D conversion thing.
Anyone: Is the Delta 1010 is as good-sounding as say the Motu stuff? Are the Digi 001's converters really crap?
Charger (since you worked at Digi): If Digi's not using AKM like everyone else seems to be using (except the manufacturers using crystal), what are they using and is it any better than, say, a consumer card codec?
Gidge: Did you ever find out if the 1010lt's codecs sound comparable to the racked 1010?
I'm in the market for something with as high quality a converter as I can afford, and I only need 4 ins, max. Don't care about outs, because once it's a file in the 'puter, it stays there until i take the file to a pro studio for mastering/finalizing. I have Cubase right now and don't know if I can export those files to a format that a Pro studio (probably running Pro Tools TDM) can use. The recording hw/sw I have is a sort of inherited hodge-podge mess and I just want to get the right stuff when I clean it up. The actual computers (a built PIII and G3) meet even Digi's cranky compato requirments, so that's not at issue. What is at issue is spending $$ only once to get set up with the right system. For me, this converter factor is key.
Thanks in advance for your input.
