ENIGMACODE
Hello Hello ??
I got some GREAT advice here last month from Rod Gervais in regard to proper wall construction and keeping NEW Walls from direct contact with the existing structure to help isolate sound ....
And I think I put it all to good use as illustrated here with my improved Gasket Design:
http://home.ucwphilly.rr.com/livesound/stuff/combo-gas-2.jpg
I have another question in regard to allowing a 'Cut Out' for a conventional 'Thru the Wall' Air Conditioner.
First let it be known that this room is simply an all-purpose 'HOBBY Rehearsal Room' There is ABSOLUTELY NO money or space for a Ducted Air System..
NO MONEY - NO SPACE
Ok - with that said I'd like to pass on a quote that I saw here from 'Blue Bear Sound' - "Basically, if a room isn't waterproof, it's not soundproof"
My intention was to build sturdy 'Foam Gasketed Trap Doors' (for both the inside and the outside), to fully ENCOMPASS the Air Condtioner that unfortunately has to pass thru the wall ....
http://home.ucwphilly.rr.com/livesound/stuff/ac-2.jpg
WILL THESE DOORS BE TOTALLY WATERPROOF?
No - I think a 'little' leakage isn't too bad?
BUT - The MAJOR question is:
Will all my OTHER efforts to construct this FREE Floating Room be WORTH IT as a result of having to cut thru the exterior wall for the Air Conditioner??
Will this Air Conditioner Cut Out - TOTALLY cancel out my other efforts to
SEAL this room?
Thank You ....
Best Regards
Michael Fraticelli
rocknroll@ucwphilly.rr.com
NO MONEY - NO SPACE
SEAL this room?
Thank You ....
Best Regards
Michael Fraticelli
! So you need not one but TWO holes in your watertight room, the second to let air out! The same principles apply for the second hole. Make it turn multiple times and line it with sound absorbent material. Make use of convection and take your hot air out near or through the ceiling.
I know one thing for sure....trying to record in a sealed space with no air conditioning SUCKS. Been there done that. So for me, its either the whole ball of wax, or nothing. I think it becomes a realization that sets ones prioritys in place. It did for me. Anyway, thats my .02.
