agrivating stereo issue on my 1210
  • Thread starter Thread starter Chriss
Chriss
Chriss
Jitens Half Brother
it simply sometimes happens that the left stereo channel loose about 9 db in volume... and i have a gig in two weeks!!! :eek:
not good... has anyone ever experienced this???
1) You might need to replace your tonearm.
2) You might need to replace your patchcords.
The 2nd option would be a lot cheaper. But, it seems as if you need a new tonearm. :(
1) Do you wet the back of your headsdhells before you screw the onto the tonearm.
2) What kind of headshell/needles do you use?
i wet 'em, yeah, it's ortofon...if it was my patch cords then i bet the entire left channel would vanish... :( :'(
If you wet them, you need to use alcohol (preferrably Isopropryl, the higher the percentage the better). ;)
Plus....... the Ortofons that are an all-in-one piece are not good for your tone-arms. Purchase the Ortofons that attach to headshells. ;)
Good luck my brother. :cool:
i use concorde... nightclub e... i'll try that alcohol thing, cause damn, it be bugger to loose the lest channel at the rave...
