K
Knopfler Fan
Currently, I am not using any software program to mix the tracks recorded with the Fostex. I try to bounce and mix everything using that little red machine.
As a general rule of thumb, do you add effects, mastering and etc...when you bounce the tracks to 5/6? Or, do you bounce the tracks "dry"?
I have noticed that if I bounce the tracks "wet" and then bounce additional tracks onto the bounced track, the result is not that great. In fact, it sounds a bit distorted-- almost as if it's clipping, but the level indicator shows that it's way below the 0 dbl. So, I'm not quite sure what it is. Perhaps bouncing has caused the guality of the sound to deteriorate? Is that possible given it's a digital recorder?
Is there a rule of thumb to bouncing tracks?
Thanks in advance.
KF
Btw, sorry about posting it to the previous thread. I press the wrong button.
Thanks in advance.
KF
