Adventures in Woodworking: The Workbench
blaumph2cool
So after absorbing as much as i could about guitar building and some general woodworking (including some great feedback from folks here), i finally got down to brass tax and began the actual journey.
After some time i decided on the Ryobi 2HP Plunge router. and so begun the sickness of buying more and more tools.
First order of business was to build a solid work bench.
Got to use my router first thing making the channels for the rod span joints.
Here is my first jig so i could make the routes straight on the spans
The bench top is 2 3/4" MDF laminated together. Drilling for the sheetscrews w/ countersync. I plan to drill dog holes leater so i spaced the screws accordingly.
Glue on the top piece and then i spread with a paint roller for even coating. (actually used more than in the pic)
And now I have a solid work space.
I still need to seal the top. I am thinking about just using a shellac and maybe putting some trim around the sides.
Good Job...:thumbs up:
Some bigger pictures would be cool..
Don't worry too much about sealing the bench top as anything will do. You will most likely be using a soft carpet cover or cardboard sheet over it pretty soon.:)
Apart from the bench dogs what else are you planning as built in vice or clamping if anything?
I fixed the images so they should be better now. (just started using google image)
plan on adding some hardwood in the vice so i won't mare my work while using the vise. More on that later.
I also have a small assortment of clamps, but i am learning that i need more.
I'll post some more pics of my tools and what i am working with, my main pieces are.
Plunge Router
7 1/4 Circular Saw
Hand jig saw
Dremal
Plam Sander
1/2" Corded Drill
18v Cordless Drill
one other thing...my first time using the router i was not prepared for the head-to-toe covering in shavings and dust i would receive.
Now i know why they use dust collectors. :eek:
Nice One! That should serve you well.
Good choice on the router. It's a solid tool for the price.
Yeah, that probably isn't a good idea.
Always keep your eye out for clamps at yard sales, flea markets, etc.
Clamps are good and you can't have enough. There are also a ton of ways to make clamps. I'll post some later, Klemsia clamps, spool clamps, you name it...
lol.... You ain't seen nothing yet..;)
Seriously keep an old vac handy until you can get a decent shop vac. I don't use one for routing anymore cos they just get in the way. I always use dust extraction though when it's airborne stuff and not wood chips.. Far more important.
