Starstreams
Member
I've just replaced a second Amp in my Event ASP-6's, and I baby the heck out of these things. (For the money they sounded great)
Now I've got my recording sound tech friend in contact with Event getting the crossover specs so he can convert them to passive in a way that retains the factory frequency curve. I'm done with active speakers. I'm not implying that everyone has issues with their active speakers, and I'm sure many of you love your monitors, but I'm very worried about this trend.
I'm disappointed that it's becoming more and more difficult to find passive near field monitors. And the manufactures are loving it, because they're putting junk amps in these things, and what ever else they want.
Passive monitors are usually cheaper and you can spend the extra money you save on a good professional amp. If we keep buying active, then that is what the trend will be, .. it looks like it's already going that way..sad.
Here are a few negatives about active monitors imo:
1. You have to have a power cord for each speaker. Not so cool if you have 3 or 4 different reference monitors in the control room.
2. Having a transformer near the speakers and circuitry inside the cabinet is usually not a good thing, no matter how shielded it is. Turn on a halogen lamp and see what happens.
3. You have more circuitry in the cabinet to vibrate and come loose
4. You have more heat in the cabinet from the circuitry to fry out the amp, and heat up the speaker voice coils.
5. More expensive to fix when something goes wrong.
6. Because each speaker has it's own amp built in, there's always the possibility of phase issues if the amps are not perfectly matched. Because now you have two power sources that can be mismatched. Electronics go out of range. However, if you have an external amp powering passive speakers (One power source), it will always put out a consistent signal to both L and R years later.
Does it make sense to spend $1000 on two active speakers that might last you 5 years, or spend another 200 to get both - a set of passives and a good amp that will last you 20 or 30 years. I'm not trying to sound arrogant, I'm just worried that one day we won't be able to find passive speakers or they might be very expensive because they are not in supply.
Any comments? If you disagree please say why so we can have a discussion.
I hope someone feels the same about this concern?
