guitar-dave
I have just bought some active monitors, and headphones for my DAW. The problem is connecting them both to my PC. I have an EMU 1212m sound card that has a left and right balanced TRS output. I want to connect both my monitors, and headphone amp to this output, and have a passive hardware volume control for the speakers.
My plan is to build a line splitter, to send the signal to my headphone amp or speakers, via a simple flick switch. When the switch is on the monitor position, a passive volume control will be bought into the circuit (a potentiometer basically).
So, I will need the following audio grade parts:
Switches
Potentiometer
6 TRS Input sockets
Wire to connect things up
A box to house it all in
My problems are:
1. What switches will I use, do I need one per channel? I have only ever worked with DC wiring, and I don’t know a switch that will keep all three signals per channel separate (hot, cold, and ground). Am I right in thinking I need a two triple pole, double throw switches
2. What wire shall I use for connecting inputs/outputs/switch etc? Will sections of mic cable do?
3. What potentiometer shall I use? Linear, logarithmic? What value?
Can anyone give me some idea what components I need? I’m in the UK, and will be buying them from RC components. If anyone knows a product available like this, please let me know!
Any comments or thoughts are greatly appreciated!
Dave
Switches
Potentiometer
6 TRS Input sockets
My problems are:
Dave
