The pro versions won't false trigger at all as long as your technique is decent and you set the brain up properly.
The most common problem people have with kick triggers is that some people will rest the beater on the head between hits. You don't hear it acoustically because of everything else that's going on. But the triggers will pick that up. Same with guys that play ghost strokes on the snare without meaning to.
For the most part, setting up the brain so it works with your playing style is a bigger issue than the triggers themselves.
BTW, I have always had problems with the Redshot triggers. It puts the sensor too far away from the edge, so it picks up more random vibration.
