acoustic guitar miking
  • Thread starter Thread starter Stark444
Stark444
Stark444
or something with a resonating chamber
i read that if i want a woody sound, use a large condenser
if i want a bright sound, use a small
what is the difference between "bright" and "woody"?
The difference between bright and woody, I would assume,, is the difference between how much string and pick (bright) you are hearing versus how much of the guitar's body...
It's sort of something you have to play around with to have points of reference.
It's like asking what the difference between green and blue is. If you've never seen them, it's impossible to explain it to you.
Also, there's the fact that, when I say "woody" or "bright," I'm probably conjuring entirely different examples of what those tones are than some other dude using the same words.
However, I think those sorts of tonal differences are gonna have a lot more to do with how you position the mic than with whether you use a SDC or a LDC, especially if you are putting the mics in the near field.
Not to say mic choice doesn't matter, but whichever you end up going with, knowing where to put it is priority number one.
Specific example: a mic positioned about six inches away from the twelfth fret, pointing straight at it, is gonna have a significantly brighter tone than one positioned about six inches from the bridge, pointing past the bridge and away from the soundhole. Try those two out with whatever mic you've got and see if any points of reference start to click for you.
As a point of ref.. I've found Earthwork's 'QTC1 can do rich woody' tones. Here is an example where a flat, neutral, (very) small diaphragm, can be ribbon' like in some ways, have no hype on top, yet have plenty of articulation and 'presence (-if perhaps by a different means and style than a 'top boost.
It's not quite as simple as "bright" and "woody", assuming we agreed what those words mean.
There's a general school of thought that you use SDCs on large sound sources (guitars / pianos etc.) and LDCs on small sound sources (voice etc.).
Most people will reach for an SDC (or two) first on an acoustic guitar over an LDC. The topic has been done to death over in the Microphone forum. I suggest you head over there and read some of the sticky threads to get an understanding of why this is so.
This is not to say that you can't use an LDC on an acoustic guitar - it depends upon a lot of factors relating to the type of music and recording you're trying to achieve.
