G
Goss-stick
So i bought sone foam to better tge sound in my room. I'm renting so i don't/can't put the adhesive on the walls and foam. Whats the best temporarily and best way to put up foam on the wall?
.....here we go..........So i bought sone foam to better tge sound in my room. I'm renting so i don't/can't put the adhesive on the walls and foam. Whats the best temporarily and best way to put up foam on the wall?
Oh wrong discussion wrong?
Acoustic foam question?
Well, that too. It should probably go in the "Studio Build" forum...
I use acoustic foam too but didn't want a lot of holes or glue on my walls. what I ended up doing was buying 4 x 8 sheets of styrofoam insulation. i cut the sheets into the dimensions i needed (2x4 & 4x8 met my needs) and glued the acoustic foam to the styrofoam pads. I used cheap music stands to hold up the sheets i even thumtacked nylon string to the ceiling and stapled the string to the back of the pads for different heights. and I can move the sheets around the room to affect the acoustics. it doesn't necessarily help with low end issues but there is a differance and it helpedSo i bought sone foam to better tge sound in my room. I'm renting so i don't/can't put the adhesive on the walls and foam. Whats the best temporarily and best way to put up foam on the wall?
