I'm using my mbox 2 with cubase 5 and I have one xlr mic going into input one. Is there any way to achieve stereo recording other than panning two tracks? I'd appreciate any suggestions.
Stereo recording is *not* an electronic option. It is a way to use *2 or more mics* to create a model (it's only a model) of what you would have heard if you had been there when it was recorded. The only way to achieve this with one mic is to do what I did-rupture one of your eardrums beyond any hope of surgical repair! I advise against it, personally.-Richie
At first I thought this was a foolish question, but I realized there's no such thing as a foolish question, only a foolish answer, so this fool (me) decided to give you an answer...
By definition, stereo means "two", so you need either a stereo mic or to record twice then pan, but there are two ways you can create a stereo effect at mixdown with one mic and only one channel when recording only one take on one track with a mono microphone:
1) Take the mono track and pan it back and forth (L and R) like they did in the early days of stereo (jim hendrix, etc)
2) Take the mono track and run it thru a stereo simulation effect.
This probably isn't the sound you're looking for, but you asked a question and these are two ways you can achieve a stereo recording (at mixdown).
Record with one mic, place it slap bang in the centre of the mix, and apply a stereo type effect to it.. reverb, chorus, auto pan via your aux...
That would give you some sort of spatial width, I'd imagine...
Or you could copy the track, invert the polarity of the copy and put it in exactly the same spot at the same volume and the whole "how do I make this stereo?" problem will magically disappear...
There is a difference between stereo and two panned mono tracks. To be stereo, you must record with multiple mics using a proper stereo micing technique.
Without getting into it, the difference is more than semantic.
