T
Tomi M.
Cheers everyone!
This picture shows John's (?) idea of saving some space: http://www.saecollege.de/reference_material/images/My Wall 2.gif , what is the STC figure of this construction? Would it be a lot better if constructed using 2 walls using resilient channel or staggered studs construction? I need pretty good STC. I'm building my studio/live room mainly for band rehearsal place (the studio side is an added bonus
). I need to use as little space for walls, floor and ceiling as possible as the space is limited. I think the size of the house is about 6 m wide, 14 m long and at the moment 2,20 m high. I checked the ceiling joists and seems it would be possible to heighten them adding new joists above the old ones and cutting the old joists off. This would add at least 0,20 m to the height... little but still more.
About John's room: I thought of putting at least 2 plaster sheets (of differrent thickness), maybe with plywood in the middle. Which kind of plywood is recommended? And is the 50mm insulation made with fibreglass? Could that 75mm insulation be rockwool or what is that recommended Polyester insulation?
As the live room will be mainly for band rehearsing, which kinds of acoustical treatment I should consider? I though of making one wall as non-parallel wall made to work as a slat resonator. Maybe putting basstraps to other corners. What else I should consider? I might get acoustical sheets (fabric covered rigid wool?), are those good for the ceiling? Let me know what you think. And sorry I can't yet give you any accurate measurements of the room I have, but it will be about 6x10x2.5m (w:l:h)...
Thanks in advance!
t0mi
Thanks in advance!
t0mi
