R
radiorickm
Ok...i just rewired my entire PA system, bi-amping it. tired of soldering now!.
anyway, i'm sure i did this right....but at 4:00 in the morning, thought i better get one of the ee types to check that i ain't going to blow somehting up
I have a 3 conductor wire running to my speakers. So, insted of running separate cables for the low and hi enclosures, i used the 3 conductor wire.
i have the 2 commons/negatives together, and a + for the hi, and a + for the low.
running the negatives together will not hurt anything will it? after all, they are probably connected together in the amp eventually anyways? right?
(ps....it's plugged in and working.....no smoke yet)
Don't confuse ground loops with shielding, I haven't. I also said that this was theory (something I read somewhere, I probably picked this up from an audiophile purist) I also said my personal experience did not bare this out. Having said that, when you go to eliminating noise for a clean quite system in a studio, I think this is a valid consideration. I also said that I use oxygen free cables, I didn't say that anyone else should and I don't, at this point, think they are a waste of money. I have a set that are not oxygen free that are 12 gauge enclosed in a clear protective covering that have turned green. The others have not. Since you probably know more than me maybe you could explain how voltage or current is transmitted through a multistrand cable and how oxidation would or would not effect it.
