About mic shootouts, tests, etc...
  • Thread starter Thread starter JuliánFernández
The poll I would like to see would assess the average speakers that HR.com folks use to listen to what's been posted.
chessrock said:
Aside from the fact that a professional drummer is just going to play a heck of a lot better ...
... professional drummers generally make pretty significant investments in their kit. It's not unusual for a pro drummer to have a crash or ride cymbal that cost him more money than the most expensive microphone in your collection.
And there's very good reason for that. Money invested in the kit will pay very large dividends in terms of sound quality and fidelity of your recording (making the engineer look better than he is), whereas money spent in the signal chain will make relatively small differences.
You can a/b two mics and hear a clear preference most of the time, no question. But switch out a cymbal or change a head? Forget about it. The difference can be so completely drastic that you'll wonder why you even spend 1% of your brain energy on mic selection. The 10% improvement you might get switching out mics will be completely dwarfed by the 80% improvement that you'll hear with a better kit.
People who post questions like "what mic should I use to get better crack out of my snare?" or "what mic pre should I use to make my cymbals less harsh?" and so on are stuck in flawed mentality ... most likely because they have yet to hear what a good kit truly sounds like.
Oh, yes. Ditto for things like the right strings for your guitar, different gauges of picks, 8" vs 12" speaker and even some guitar cables can sound different.
JuliánFernández said:
Ok, about the "I can listen to a recording of white noise and know pretty much how a mic will sound on different sources", i know VERY little people that can say something like that, and those people certainly don´t need to use listeningsessions to know how a Portico sounds on a snare... I believe most people that use that kind of reference (mic shootout), don´t have much experience with gear... (at least, high end gear). So maybe you´re not an standard in that way...
No, I'm not standard, but it's like anything else, practice makes perfect. I read that Klaus Heyne primarily uses his own voice, counting to three, to test mics. No doubt he has other tests too, but the first test is his own voice, because he's used to it. I have grown very accustomed to white noise . . . it is perhaps not the ideal tool for discerning subtlety at the level Heyne works at, but I find that in the low end, differences usually aren't very subtle.
Turn it around the other way, would you accept a matched pair of mics where the manufacturer said they recorded two different snare drum hits and compared?
For me, it´s simple. I wanna play and record with great musicians. Let´s not forget that we are recording MUSIC... Is not about the pres, is about the music!!! I´ll trade every single piece of high end equipment in the world for crappy gear and top notch musicians.
Gear is tool, not an end. Music is the end.
Clips of sloopy playing are useless unless you´re planinng to record sloopy players. I certainly don´t.
Probably 95% of people here are recording either themselves, their friends, or a few local bands, maybe for money, maybe not. A few people here have commercial studios that book larger stuff, indie releases, etc. We have had major label types here before, not sure if there are any at the moment.
But the point remains, most people can't choose to only record great musicians. Especially if they are recording themselves ;)
Heck, go on over to REP and look up a thread called "vocal comping" or something similar, and read about how all the real actual big names pros are griping about recording vocalists, guitarists, drummers, etc., who suck raw eggs, and having to waste hours upon end with tuning and edits.
Chill, man. Let the music play . . .
we all listen to different things. ie: los texas wranglers are cheesy and generic with horrid lyrics, hokey rhythms, and forgetable vocals.
but this is homerecording.com. if you want to tell someone they suck, go to analdrummers.com
i think that mic shoot outs are good for comparing the mics in the shoot out relative to each other. the problem for me is that mic placement, room acoustics, pre (and rest of the signal chain through the a/d's), etc. make such a huge difference that the sound samples will most likely have little value for figuring out how the mics will sound for your uses, unless they also include a mic in the shoot out that you own, which you can then use as a relative standard to the other mics.
all that imho.
Gear does matter as does the room.
So does talent in front of the mic and behind the mic. Pink Floyd's "Dark Side of the Moon" probably would not sound the same tracked by some guy in his bedroom with a Digi 002 though.
The problem of the online recording community mindset is that most people believe that if they want to achieve a professional result then the result must necessarily flow from gear purchases.
I think that for those recording themselves it's easy to fall into the trap of spending too much time working with the gear and not enough time working on performing well. Sometimes the two things overlap, sometimes not. I do a lot of slow, detailed practice on gtr. I enjoy it but there's no point recording it. I also like to do vocalizations of my gtr lines as I'm working out how I want something to sound, and don't want to record that either. Generally I get my best recording takes when I've been practicing a lot and recording a little.
But gear shootouts are interesting when the playing's fairly clean so the gear characteristics can come through.
I believe Harvey Reid recorded his 1989 classic "Solo Guitar Sketchbook" using AT4051 mics through Mackie pres in his home recording space. It's still one of the best solo acou guit albums I've ever heard.
You guys put too much thought into this.
90% of the recordings posted on the net are probably 128kbps mp3's anyway. You can't hear any detail from them anyway.
amra said:
...90% of the recordings posted on the net are probably 128kbps mp3's anyway. You can't hear any detail from them anyway.
I've heard some good mp3s at 128. But higher res is better. I think the artifacts that mp3 conversion create can sometimes be a good thing when you're doing critical listening because they seem to accentuate imbalances that already exist rather than create new ones. IME a good sounding wav converts very well to 128 kbps mp3.
I think the skill that matters for a mic or pre shootout is consistancy. Be it drum hit's, vocal lines, or guitar picking, it has to be the exact same position, velocity, attack, formants, etc., on every take. That's where a professional may be better for this, though only if they fully appreciate and apply this.
In any case, multiple samples from multiple people are really necessary before you can start to form an opinion on a mic or pre without getting it in your own hands, and how it sounds in a great room with a great instrument played by a great player may be less useful to some Homerecording members than how it sounds in a typical home studio with less than great instruments and technique. But best is to hear a variety of samples from a variety of situations.
To that end, I really wish we had a HR gear sample database that over the course of a few months might become a rich source of such samples.
...multiple samples from multiple people are really necessary before you can start to form an opinion on a mic or pre without getting it in your own hands...
Agreed.
...wish we had a HR gear sample database...
Good idea.
This was a really interesting thread for me. Honestly, couldn't the answer to "what piece of gear will improve my recording the most" be "a metronome" much of the time?
I think what i am getting from it and most of the stuff i have been reading about and doing with recording is that it is all about what to do with $$ and time. It is pointless to try to home record the album that will break you out to be a huge star if your playing and singing and instruments sound like crap (the semi-famous Daneil Johnston notwithstanding).
What i have learned, and what is not always apparent from topic-specific posts and beginners guides and such, is that expensive gear is often pretty darn far down the road in terms of "what will give me the most impact per dollar and minute" It would be really interesting to have people with more experience put it all in a pile and sort it out, make it a sticky in the newbie section, etc.
My take (assuming someone has something like a budget condensor and a budget interface with a built in pre, and reaper or a demo version of one of the big recording packages):
1. source- instruments that sound good, have new strings heads, are tuned. Amps that don't wreck tone, voices that are on key etc.
2. talent - finger notes cleanly, uses decent rythym, has some sense of musical creativity when needed etc.
2. room- bass absorbtion, reflection taming. Isolation from outside noise to a degree that will not interfere with a recording.
3. Monitors that can reasonably give insight as to the actualy recorded signal.
4. practice, such as recording the same source from different mic positions to actually see how mic placement affects the result, learning to use software, learning (such a big deal) proper gain staging, etc.
So far my feeling is that these are things that you need to address before you start saying "my mic is too bright" or "I want to warm up my signal, should i get a tube pre" or whatever.
That said, i have something like 8 mics right now and 6 channels of 'acceptable' (better than the behringer 802 I started with anyway) budget pres. My talent is still piss poor and my room is just stating to make me feel like i have something to work with. Intruments, amps, etc are ok, but not great yet. I will likely invest in some new mics from the group buys that are coming up, but only because the timing and price are right.
What i know for sure is that 1-4 will continue to give me much more return on my time and money investment than moving up to different more expensive pres, converters, mics, etc. If i had the experience and understand when i started out with this *hobby* i would have used the $1000-1600 that i have put into mics, patchbays, snakes, pre channels, etc that i barely ever use (yet) into room treatment, heads for drums, cymbals, amp upgrades, and time practicing playing and recording, gotten some real knowledge, and only THEN started to upgrade gear and buy extra mics to build on that. That said i think i have gotten lucky and made good investments so the stuff i barely use will get used as i work on the other stuff, but it could have been different trying to be able to do the most, with the least, earliest.
Daav.
...little people that can say something like that, and those people certainly don´t need to use listeningsessions to know how a Portico sounds on a snare... I believe most people that use that kind of reference (mic shootout), don´t have much experience with gear... (at least, high end gear). So maybe you´re not an standard in that way...
Then how would a "pro." go about hearing those differences. And if you say look at a spec. sheet I'm done with this thread.
You´re right, andyhix. I do have my homestudio too, and i understand your point; but i´m offering my point to those who wanna become better HOMEproducers/HOMEengineers.
QUOTE]
Playing,equipment, mixing "ears" and experience...I believe they are all important if you are going the "one man band/producer/engineer" route. If you want to be a great player, focus on playing. If you want to be a good engineer, focus on experience there. As a sound engineer, you should be able to learn things from both bad players and good players. Doesn't mean the overall production of music with bad players is going to appeal to the listening audience because it is bad playing with good engineering, but it will challenge you to explore methods for salvaging less-than-stellar performances.
So I believe they are all important to a good recording; performance, equipment, and engineering abilities. Guess it really depends on whether you are a professional instrumentalist or a professional engineer as to which one you should focus your time/money on.
Yup. A good kit witha good player is a thing to behold.... like a guy who can take a snare and really get a nice consistant rim shot... you have to have both the kit and the player... then mics and the other minutia is pretty insignificant. Want more crack out of the snare... make sure the snare has crack to begin with. Want more sizzle from a cymbal, don't use pie plates.
