J
Jim Soloway
My problem is strictly recording my guitar. I'm running a line out from my amp to the 788. In order to get a strong enough signal to my 788, the peaks in the hotter passages end up overdriving the converters. As I understand it, the compressor in the 788 is digital and kicks in after the converts so it won't help with this.
It seems to me that the solution is a compressor up front before the signal hits the input. That raises two questions.
1. should I compress the signal before or after the amp?
2. should I be using an all purpose compressor like the RNC or should I be using a guitar specific compressor like the Carl Martin?
Thanks for the input.
